For Inventor 2012?
Solved by johnsonshiue. Go to Solution.
Hi Robert,
Please share an example here so I can take a look at the joke and see if I should laugh or cry. If the files are proprietary, send them directly to me (johnson.shiue@autodesk.com).
Many thanks!
I'm seeing a similar issue with one assembly this a number of LOD's and View Reps.
I'm trying to see which one or the combination of both is causing an issue.
Hi Blair,
If you find one, please share it with me directly (johnson.shiue@autodesk.com). The behavior is wrong and it should be fixed.
Many thanks!
I deleted all the View Reps and set the View Reps to Default. Only using the LOD's to create the desired IDW drawing views.
Drawings regen immediately.
