I am builiding a new computer at work and I was wondering what type of graphics card should i be looking for, geforce, or quadro. I currently run inventor simulation suite 2010 with direct3d option. Also is SLI support and or recommended.
Solved by sam_m. Go to Solution.
not to sound rude, but have you done a search??? this has be covered to death...
Get the most powerful DirectX card you can afford whether it's GeForce or Quadro... Benchmark of Dx GPU's:
http://www.videocardbenchmark.net/high_end_gpus.html
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
I actually have a similar question regarding gpu's for the program i currently have a 400$ dell laptop (its terrible BTW) and i am going to build a new desktop to run CAD and a few other things and im on a 600$ budget so with that said should i have any issues with using a nvidia gtx 660 of 650 ti boost they are basically the same card the 660 is slightly more powerful both are really good benchmark wise
