After I have used Inventor 2012 from a remote computer and then suddenly when I came back to the office I got this error message attached here.
I cant find out what the problems are and I have tried several different setting in the Application options/Hardware settings.
Any Ideas what I should do?
Thats not an error message. That is the box you get when you go to tools..application options..hardware tab and press the diagnostics button. It is simply showing a quick overview of your hardware settings.
Somehow you must have accessed that. Just close it and try your remote session again sometime and if it comes back up without you doing anything then you might have found a bug but I'm willing to bet you triggered that diagnostics button somehow.
No I dont get it undert the Tools/application options.
I get it everytime i press the icons about shadows and how the parts should be viewed.
This came up after I have run the computer by "remote" from another computer
The system has somehow turned down the quality to save time when using a remote computer
Most likely, the options in your Remote Desktop Connection dialog box have over-ridden you desktop settings.
Most remote desktop connections are limited to 32bit color.
Open your NVIDIA Control Panel and check your screen resolution & color depth settings.
