I have a cantilevered arm that must rotate from 0 to 110 degrees. I would like to lift this arm with a hydraulic cylinder. How do I calculate the actual load using Dynamic Simulation in Inventor 2012 .
In the scenario of lifting this arm the load will actually decrease at some point of rotaion. I would like to see the true loads throughout its rotation. Can anyone please provide the step by step procedure to do this.
I recommend purchasing the book by Wasim Younis.
Can you attach your assembly here?
