@Mustang69 wrote:
What I really lack in Inventor is good presentation tools like doing brochures and customer quotations.
Solid Works seams to be really good at this
SolidWorks or do you mean SolidWorks Composer?
You might look at Inventor Publisher.
We use Adobe Indesign for our manuals and brochures.
I remember some years back seeing a presentation from Solidworks on 3D Via. That is a software that had a lot of niffty tools and may work for you, but it is pricey.
While I have never used it, what I think I have heard about Inventor Fusion, this might work for you as well.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hello Mustang69,
What kind of presentation tools are you looking to create? You mention brochures and customer quotations, but I'm not quite sure if you're looking for Inventor to create a photo-realistic document with advanced text formatting capabilities. If so, then as far as I'm aware of, no, that does not exist within Inventor. What Inventor can create are images and videos that can be incorporated downstream into your marketing workflow. Also present is the capabilities to capture Parts Lists that can be consumed downstream as well. Another aspect would be Simulation and Motion Analysis to present to your potential clients either from a website or printed media. I hope that helps, any feedback is welcomed.
I just attended a SolidWorks Composer presentation - I could be wrong, but I think they said it was formerly 3D Via Composer, purchased by SolidWorks and renamed. In any case - I suspect the OP saw something else other than vanilla SolidWorks. An additional cost functionality.....
I am not familiar with Inventor Publisher, but I think it is important to at least be comparing apples to apples....
Inventor Fusion no longer exists.
Perhaps you meant Fusion 360.
inventor publisher is the closet product i can think of
but from what i am reading in the forums its not a very good product
DarrenP
Publisher is a pretty good product if you watch what you are doing. And the cost difference between what 3D Via sold for a couple years ago (not sure about current cost) around 8,000 US compared to only 1,000 US for Publisher it was quite a steal for a lot of clients. It is definately a niche product though and great for creating fast imagery that can be consumed in MS Word or Adobe Illustrator for image placement. Most of these programs though need to revolve around your workflow. If you don't need updating of the imagery during WIP changes then it doesn't really matter what you use on the back end for manuals. The bidirectional linking in the software is nice for WIP and marketing that happen side by side, but that tends not to be the case at most companies.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Yes I'm looking for doing photo realistic or nice graphic documents in wich I can decsribe the product I have done
Making images in Inventor is really embarasing comparing how nice Solid Works does it
Inventor has very very crude tools for doing images and it is time consuming.
Its a mattor of working with several programs to in the end get some decent presentation.
Making videos in Inventor is actually a joke.
Many times when I have visit a customers and got the oportunity to se my competitors documents made from within Solid Works I got really amased!
Quite recently I got a demostration from Solid Works sales people and was then convinced how easy and fast they did nice and simple documentations.
Well I have learned not to listen to much to sales people so thats the reason I also place the question here to maybe get some real hands on information! 🙂
http://www.youtube.com/watch?v=RfnzEpL_Q6M
This is what i need! 🙂
JD, you might be right. When I saw this presentation it was back with SW 2009. And Fusion 360 sounds more accurate, but that is the problem with using an older issue of Inventor. I still have Inventor Fusion on my system.
