Inventor General Discussion
New Member
deonlemmer
Message 1 of 5 (121 Views)
Going from a flat pattern to a pressed part
121 Views, 4 Replies
06-21-2012 07:52 AM
I have the flat pattern of my part, and the press tool. Is there a way to form the flat pattern to the shape of the press tool?
JDMather
Message 2 of 5 (107 Views)
Re: Going from a flat pattern to a pressed part
06-21-2012 08:58 AM in reply to: deonlemmer
Attach the files here.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
mcgyvr
Message 3 of 5 (103 Views)
06-21-2012 09:12 AM in reply to: JDMather
Seems like such a backasswards process..
If I understand you right, I would place the die and the flat pattern into an assembly file. Constrain the die/flat in the right place then edit the flat pattern in the assembly and create a sketch and project the die edges onto the flat.. Then fold the flat up using those projected lines..
How is it you have a flat pattern and have build a die but don't have the as formed part..How was the die built? How were the flat dimensions defined?
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
New Member
deonlemmer
Message 4 of 5 (77 Views)
06-21-2012 10:59 PM in reply to: mcgyvr
I thought about it and decided that it is not worth the trouble to try and get to the pressed part. Will do some trail and error in the workshop. Thanks for the reply.
JDMather
Message 5 of 5 (68 Views)
06-22-2012 04:31 AM in reply to: deonlemmer
Could be trivially easy.
Attach your files here.
