Inventor Forum
Globoidal Cams
7 REPLIES 7
Message 1 of 8
JackWendorf6760
677 Views, 7 Replies
Globoidal Cams
Has anybody design a globiodal cam in inventor 10, if so whats the best pratice to designing this cam?
thanks
Jack Wendorf
7 REPLIES 7
Message 2 of 8
mpatchus
in reply to: JackWendorf6760
There was a pretty good paper published awhile back in the World Academy of Science, Engineering and Technology 18 2008.  It described several different modeling methods.
Here's a link to the paper.
http://www.waset.org/journals/waset/v18/v18-29.pdf
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 3 of 8
JDMather
Are you using Inventor 10 or are you really using Inventor 2010?
This cylindrical cam tutorial (there is a Cylindrical Cam tool directly in later releases of Inventor) along with the previously posted link might get you started to a solution.  Attach your file and cam specifications here if you get stuck.
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%2011%20Tutorial%2011.pdf
This is a more general method that might be adaptable to your need rather than the built in tool in later releases.
Message 4 of 8
JackWendorf6760
in reply to: mpatchus
Message 5 of 8
JackWendorf6760
in reply to: JDMather
2010, thanks
Message 6 of 8
Could you post another link to this I would like to view this as well and I get an error as if the page has been removed?
Message 7 of 8
JDMather
A lot has changed in Inventor since this was written - there might be a better way in current release.
Attach your attempt here if you get stuck.
Message 8 of 8
Thank you!
