Has anybody design a globiodal cam in inventor 10, if so whats the best pratice to designing this cam?
thanks
Jack Wendorf
Solved by JDMather. Go to Solution.
Solved by mpatchus. Go to Solution.
There was a pretty good paper published awhile back in the World Academy of Science, Engineering and Technology 18 2008. It described several different modeling methods.
Here's a link to the paper.
http://www.waset.org/journals/waset/v18/v18-29.pdf
Are you using Inventor 10 or are you really using Inventor 2010?
This cylindrical cam tutorial (there is a Cylindrical Cam tool directly in later releases of Inventor) along with the previously posted link might get you started to a solution. Attach your file and cam specifications here if you get stuck.
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%2011%20Tutorial%2011.pdf
This is a more general method that might be adaptable to your need rather than the built in tool in later releases.
Could you post another link to this I would like to view this as well and I get an error as if the page has been removed?
A lot has changed in Inventor since this was written - there might be a better way in current release.
Attach your attempt here if you get stuck.
