Ok so where are Global Forms saved in 2013?
Solved by SBix26. Go to Solution.
Hi Lance_White,
I think Mike Deck has the answer you're after at this link:
http://forums.autodesk.com/t5/Autodesk-Inventor/Global-Forms-in-network/td-p/3026716
I hope this helps.
Curtis
