Hello guys I was just wondering anu=y one having this issue, ghost lines from exported components.
Its not that problematic but it shure is annoying.
Hello Mike
I See this in this assembly Im working right now there is nothein there, not hidden or with visibility off, this just keeps appearing but if I zoom in it dissapears.
Im running Inventor Pro 2014
Windows 7 64
If you go into Application Options-Assembly and uncheck 'Enable Express Mode Workflows' does the ghosting go away ? (you may have to reopen the file)
Or on the Assemble - Productivity tab switch between Express mode and full mode ?
Regards
Martin
This does not work, I have the same problem Inventor 2014. Seems like 2014 is FULL of bugs, actually more like a downgrade from 2013 if you ask me.
Most of these graphics issues in 2014 are know to Autodesk and should be addressed in SP1. Historically SP1 has been released in September. So here is to hoping they have this and other graphic anomalies resolved.
Can those of you experiencing this ghosting problem confirm if the problem persists after installing Service Pack 1 for Inventor 2014? Also, are you all running the latest Autodesk Certified graphics drivers?
http://www.autodesk.com/graphics-hardware
Take a look at this post.
