Inventor Forum
ghost box on screen, video driver setting??
5 REPLIES 5
472 Views, 5 Replies
I have a "ghost box" that stays on screen after opening a tool like measure
which has a drop down. If I pick any option from the drop down, then I get
a "ghost box". It will go away as soon as I pan or zoom, but it is annoying.
Is it my graphics card setting? I'm not sure how it should be set up for the
best performance with IV6.
Any help or suggestions would be great.
Thanks, Josh
The graphics driver has not been certified.
The graphics driver ID is NVIDIA Corporation\Quadro4 750 XGL/AGP/SSE\1.4.0
Graphics driver file nv4_disp.dll is version 6.13.10.4109
Using Full optimization (this is the recommended setting)
SwapType = 2
Workarounds = 0x10080000
Workarounds2 = 0x00000040
The display is using 32-bit color
HW Library Version = Win2K - $Revision: #3 $
HW Library Date = $DateTime: 2002/11/11 13:09:54 $
Options = 0
Warning Options = 8
Settings for optimized and conservative:
SwapType: 2, 3
Workarounds: 0x10080000, 0x10080000
Workarounds2: 0x00000040, 0x00000040
Text Options: 0x00000000, 0x00000000
OpenGL Version: 14, 14
Recommended Optimization Level: 2
Texture Font Precision: 32
Stroke Font Precision: 0.001000
Driver Rating: 0
Using OpenGL 1.1
swap behavior: swapCopy(1 or 2)
OpenGL errors: None.
5 REPLIES 5
I occasionally get a ghost box around my cursor in 5.3 and 6 and my video
driver doesn't seem to make a difference.
"Josh Beissel" wrote in message
news:D08852B110FC39173762F56738BDE8D7@in.WebX.maYIadrTaRb...
measure
get
annoying.
the
> Thanks, Josh
> SwapType = 2
> Options = 0
> Warning Options = 8
> SwapType: 2, 3
> Driver Rating: 0
> Using OpenGL 1.1
try
RMB on desktop / properties (don't recall which tab) but look for effects.
Uncheck this box. Sometimes the fade effect can hang up and produce what
you are seeing...
You should have no problems with that card...
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
measure
get
annoying.
the
> Thanks, Josh
> SwapType = 2
> Options = 0
> Warning Options = 8
> SwapType: 2, 3
> Driver Rating: 0
> Using OpenGL 1.1
Try this in Win2K and XP Pro - Turn off pointer Shadow (Control Panel - Mouse),
Turn off Use Transition Effects (Control Panel-Display) These settings will
affect all systems regardless of card & driver.
Dennis
> Thanks, Josh
> SwapType = 2
> Options = 0
> Warning Options = 8
> SwapType: 2, 3
> Driver Rating: 0
> Using OpenGL 1.1
Dennis Jeffrey
CAD Associates - Fort Wayne
Autodesk University Instructor
Autodesk ASC
(260-432-9695 x 221
Sean, Dennis "Ghost Busters"
Thanks for the tip that worked perfectly. No more ghost's
"Dennis Jeffrey" wrote in message
news:3DF6CF70.9C8927E2@cadassociates.com...
Mouse),
will
> Dennis
measure
get
annoying.
the
> > Thanks, Josh
XGL/AGP/SSE\1.4.0
> > SwapType = 2
> > Options = 0
> > Warning Options = 8
> > SwapType: 2, 3
> > Driver Rating: 0
> > Using OpenGL 1.1
> Dennis Jeffrey
> Autodesk ASC
> (260-432-9695 x 221
Thanks guys. I've been putting up with this too because I had assumed it
would take some serious voodoo to fix such a graphics problem. That's why I
need to read every post in this NG.
Mouse),
will
> Dennis
measure
get
annoying.
the
> > Thanks, Josh
XGL/AGP/SSE\1.4.0
> > SwapType = 2
> > Options = 0
> > Warning Options = 8
> > SwapType: 2, 3
> > Driver Rating: 0
> > Using OpenGL 1.1
> Dennis Jeffrey
> Autodesk ASC
> (260-432-9695 x 221
