I have a sketch that i want to show in an idw that is within a pattern of a sub-assembly that is within an upper assembly. There could be quite a few or none of the sketches to show. I am able to show them a few at a time but i would like to have the ability to get all of the sketches (to show in the idw) at once with i-logic. Does anyone know if this is possible? I appears i can change the dimensions of the sketch with i-logic but i am unable to find anything to show the sketch with i-logic.
Any help would be appreciated.
Hi! Not all sketches make sense to be shown in a drawing view. It really depends on the view direction. If the view direciton is also normal to the sketch plane, then the sketches can be included in the drawing view.
Are you not able to include model sketchs normal to the view direction? If yes, I would like to see an example of the behavior.
Thanks!
Thanks for the responce.
I am able to show the sketch i want to show. It is located within a pattern, within a subassembly, located in the upper assembly and it cumbersome to dig for each and every instance which we always show. I just wanted to know if there was a way to show multiple instances of a particularly named sketch with i-logic.
