Software used: Autodesk Inventor 2014 SP2
I’d like to discuss what we consider defect of Inventor (we faced issue on our dataset but I’m going to describe it on a standard dataset).
In some cases it is hard to predict how thumbnail of Configuration Members (iPart or iAssembly) would be oriented.
Steps to reproduce:
1. Install Inventor samples provided by Autodesk (http://download.autodesk.com/us/support/files/inventor_sample_files/Autodesk_Inventor_2014_Samples.e...).
2. Open folder
C:\Users\Public\Documents\Autodesk\Inventor 2014\Samples\models\Assemblies\Engine MKII\Components\Flywheel\
and witness the thumbnails of three IPTs (their orientation is the same to thumbnail of Configuration Factory Flywheel.ipt – axis is horizontal):
…and this is exactly what user expects.
Now let imagine user have changed his mind regarding desired orientation:
3. Open in Inventor C:\Users\Public\Documents\Autodesk\Inventor 2014\Samples\models\Assemblies\Engine MKII\Components\Flywheel.ipt
4. Using ViewCube set face that is initially «FRONT» to become «TOP»; rotate model according to new face orientation:
5. Set the view achieved as Home (fit to view) and save the file. After pressing F6 you should get something like this (axis is vertical):
6. Generate all three elements. The thumbnails in the mentioned folder are:
Is it what I’ve expected?
NO!
My expectations (images get by activating each element) ARE:
Hope the difference is clear.
I wonder what should have be done in different way to get the expected thumbnails?
Thanks in advance.
Solved by Maxim-CADman77. Go to Solution.
I didn't check this - but the first place I would experiment with changing the thumbnail is in iProperties.
Our corporate option is the same as Autodesk's default - "Active Component Iso View On Save"
...and this seems the only proper setting for the situation - http://forums.autodesk.com/t5/Inventor-General/All-iPart-iAssy-members-are-saved-with-thumbnail-of-a...
As I indicated - I did not experiment, but my thought was to create the preview and then turn off Save Preview picture once the desired image has been assigned.
Thanks but that can’t be a solution for us.
Mostly because thumbnail should update automatically on each save (nobody wants to keep in mind updating it manually)
I'm trying to follow the link - http://forums.autodesk.com/t5/Inventor-General/All-iPart-iAssy-members-are-saved-with-thumbnail-of-a... the emil and keep getting
But if I follow the link from the webmail it OKIs ther a problem with this link or with the site itself??
Have just recorded video - https://screencast.autodesk.com/main/details/95a3d5f2-e434-4f15-905c-43ccbdbe57dc.
Could, please, somebody try to reproduce the issue?
