Inventor General Discussion
Distinguished Contributor
JimSteinmeyer
Message 1 of 8 (214 Views)
generating factory part for drawings
214 Views, 7 Replies
02-12-2013 08:17 AM
I have a C-channel that I bent and then created a i-part of so that I could place both a formed and flat view in the drawing. After creating the drawing it was determined that the channel needed to be longer. Not a problem, open the factory, edit the part, open table and verify, close table and activate both parts, save and close factory. It's all good, until I run a print  and the flat part (-02) of the factory still shows the old length. Next I open the factory, select table and both members and generate. The message " not able to save factory" appears. Any ideas as to what would cause this?
Thank you
Jim
Inventor Premium 2013 SP1.1
Vault 2013- plain vanilla version
HP G71 notebook
celeron cpu w\ 4gb RAM and 64 bit system
Win 7 home premium
Ya, my boss has me running my personal machine at work.
Valued Mentor
rhasell
Message 2 of 8 (188 Views)
Re: generating factory part for drawings
02-12-2013 07:07 PM in reply to: JimSteinmeyer
Hi
Did you try re-generating the files ?
I have had a similar problem where iParts did not update the Drawing dimensions correctly,  A rebuild all fixed this.
Reg
Autodesk PDS Ultimate 2015 SP 1 Build 203
Intel Core i7 (950@3.07GHz)/Win7x64 (Home) - 12GB Ram
Nvidia GeForce GTX 560 Ti
Please Give Kudo's / accept as a solution if it solves your problem.
JimSteinmeyer
Message 3 of 8 (163 Views)
02-14-2013 11:58 AM in reply to: JimSteinmeyer
Yes. I opened the factory, selected the table and all (both) members of the factory, and then RMB and Generate. That is when I obtained the "can not save factory" responce.
Thank you
Jim
HP G71 notebook
Win 7 home premium
karthur1
Message 4 of 8 (151 Views)
02-14-2013 01:57 PM in reply to: JimSteinmeyer
Do you have the children checked out?
JimSteinmeyer
Message 5 of 8 (145 Views)
02-14-2013 03:09 PM in reply to: karthur1
Yes, in fact I haven't checked any of the assembly in yet.
Jim
HP G71 notebook
Win 7 home premium
swalton
Message 6 of 8 (131 Views)
02-15-2013 07:21 AM in reply to: JimSteinmeyer
I usually create an "update" assembly for my iComponents.  I place each member of my iPart/iAssembly in it.  I use the update all button to force each member to update.
This assembly is also handy working with Vault because i can check-out all the members and update them at once.  I find that the "generate files" command is not very reliable if the members already exist on disk or in vault.
Inventor 2014
Vault Professional 2014
JimSteinmeyer
Message 7 of 8 (121 Views)
02-15-2013 01:21 PM in reply to: swalton
So you create a dummy assembly and place one instance of each factory part in it then simply use the update icon in the Manage tab? I will have to try that and see how it works for me. Does seem like a convoluted work-around to me though.
Jim
HP G71 notebook
Win 7 home premium
karthur1
Message 8 of 8 (112 Views)
02-15-2013 02:10 PM in reply to: JimSteinmeyer
JimSteinmeyer wrote:
So you create a dummy assembly and place one instance of each factory part in it ..
Thats what I do to keep all the children in sync.  When a change is made to the parent, just open the dummy iam, check everything out and hit the update button (if its lit).
