Inventor Forum
generating factory part for drawings
7 REPLIES 7
Message 1 of 8
472 Views, 7 Replies
I have a C-channel that I bent and then created a i-part of so that I could place both a formed and flat view in the drawing. After creating the drawing it was determined that the channel needed to be longer. Not a problem, open the factory, edit the part, open table and verify, close table and activate both parts, save and close factory. It's all good, until I run a print  and the flat part (-02) of the factory still shows the old length. Next I open the factory, select table and both members and generate. The message " not able to save factory" appears. Any ideas as to what would cause this?
Thank you
7 REPLIES 7
Message 2 of 8
rhasell
Hi
Did you try re-generating the files ?
I have had a similar problem where iParts did not update the Drawing dimensions correctly,  A rebuild all fixed this.
Reg
2024.2
Please Accept as a solution / Kudos
Message 3 of 8
Yes. I opened the factory, selected the table and all (both) members of the factory, and then RMB and Generate. That is when I obtained the "can not save factory" responce.
Thank you
Message 4 of 8
karthur1
Do you have the children checked out?
Message 5 of 8
in reply to: karthur1
Yes, in fact I haven't checked any of the assembly in yet.
Message 6 of 8
swalton
I usually create an "update" assembly for my iComponents.  I place each member of my iPart/iAssembly in it.  I use the update all button to force each member to update.
This assembly is also handy working with Vault because i can check-out all the members and update them at once.  I find that the "generate files" command is not very reliable if the members already exist on disk or in vault.
Steve Walton
Inventor 2023
Vault Professional 2023
Message 7 of 8
in reply to: swalton
So you create a dummy assembly and place one instance of each factory part in it then simply use the update icon in the Manage tab? I will have to try that and see how it works for me. Does seem like a convoluted work-around to me though.
Message 8 of 8
karthur1
@Anonymous wrote:
So you create a dummy assembly and place one instance of each factory part in it ..
Thats what I do to keep all the children in sync.  When a change is made to the parent, just open the dummy iam, check everything out and hit the update button (if its lit).
