Inventor Forum
Generating a parameter
3 REPLIES 3
nige106
250 Views, 3 Replies
I need to extrude a simple shape between two planes and then get the length as a parameter. Is there anyway of generating this? All I can find is a parameter for the angle of the extrusion.
Thanks.
3 REPLIES 3
Cadmanto
in reply to: nige106
Did you look for the dimension here?  This is where you can rename it to make it easier for locating it.
Best Regards,
Scott McFadden
(Colossians 3:23-25)
mrattray
I don't a parameter is created when you do a between extrusion (I may be wrong). Can you instead find the distance between the planes? If they're offset planes, then the offset values are parameters. You could create a user parameter for the extrusion distance and assign it a value of Plane 1 offset1 + Plane 2 offset.
Mike (not Matt) Rattray
japike
in reply to: Cadmanto
How about adding an additional sketch with a dimension between the planes.
Peace,
Jeff
Inventor 2022
