Inventor Forum
Generated gears are not visible in assembly
1 REPLY 1
ilobanov
449 Views, 1 Reply
I'm new to Inventor so it might be something obvious, but I've already spent a couple of hours trying to figure it out, and searching doesn't seem to yield anything helpful.
I'm creating a pair of spur gears using Gear Generator. I can see the preview of the gears geometry when I'm in the generator dialog. However, when I click OK and a new part is generated, I can't see any generated geometry in my assembly. The part seems to be empty.
I'd appreciate any advice.
1 REPLY 1
ilobanov
in reply to: ilobanov
It turned out that two cylindrical faces used to construct the gears were not quite in the same plane, so that generated gears wouldn't be touching each other. I added assembly constraint and it now works fine.
