Inventor Forum
Generate files iAssembly
9 REPLIES 9
Message 1 of 10
oneshortplanck
1019 Views, 9 Replies
I have an assembly with around 120 variants in it.
I am getting a little annoyed having to click the OK button when asked:
"Do you want to save changes to 122.iam" and its dependants"
is there any way to set the default to OK?
(other than setting an electric motor and a poking device up)
i would like to leave it over night etc...
thanks in advance
9 REPLIES 9
Message 2 of 10
BUMP
Message 3 of 10
Cadmanto
in reply to: oneshortplanck
The only place I thought this message might be (which I wasn't holding my breath) would have been in the application options under the prompts taband it wasn't there.
I know what you are talking about and this is a pain.  Unless there is an iLogic routine that does this I am not sure there is a way around other then to keep doing what you are doing.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 10
Hey,
I've got the same problem for ±110 variants. There isn't any setting available in the "prompts" tab in the application option of Inventor 2016. Has anyone got any ideas?
If iLogic is the answer, any basic code to start with would be helpfull.
Many thanks to all who give any clues at all.
Paul
Message 5 of 10
oneshortplanck
I think I have a work around, (but as with all workarounds, Autodesk should arrange for a proper fix):
go to the ipart or Iassembly sub folder and delete all the files. make sure you have all checked out from the vault so there is no writ protection on the files if you are using one.
now generate the files and (if I remember correctly) you wont get the save messages).
Message 6 of 10
ThomasB44
Hi @Anonymous
Please try this iLogic rule :
SyntaxEditor Code Snippet
InventorVb.DocumentUpdate()
'If it is an iPart
If ThisDoc.Document.DocumentType = kPartDocumentObject Then
    Dim oDoc As PartDocument = ThisDoc.Document
    Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
    Dim oFactory As iPartFactory = oDef.iPartFactory
    Dim oRow As iPartTableRow
    For Each oRow In oFactory.TableRows
        oFactory.CreateMember(oRow)
    Next
End If
'If it is an iAssembly
If ThisDoc.Document.DocumentType = kAssemblyDocumentObject Then
    Dim oDoc As AssemblyDocument = ThisDoc.Document
    Dim oDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
    Dim oFactory As iAssemblyFactory = oDef.iAssemblyFactory
    Dim oRow As iAssemblyTableRow
    Next
End If
iLogicVb.UpdateWhenDone = True
Thomas
Mechanical Designer / Inventor Professionnal 2023
Inventor Professional EESignature
Message 7 of 10
in reply to: ThomasB44
Thomas,
this iLogic does the trick. Many many thanks! Now I can generate all files without looking (e.g. before going home). This is a solution for me!
@oneshortplanck: I'm sorry, but your work around did not seem to work here. I think you'll like Thomas his code as well. But many thanks for your suggestion.
grz
Message 8 of 10
ThomasB44
@Anonymous
You're welcome Smiley Happy
In a particular case, like populate some iProperties that are not in the factory table, members are not saved.
In fact, like with the right click command "Generate members", the members are generated if there is a model or a factory table change.
To prevent this, you can click on the "rebuild all" command before run the rule or you can add at the start of the rule :
ThisDoc.Document.Rebuild()
So in this way, Inventor believe all members have been modified and save them all, even if there is no changes, but it could be a longer operation.
Thomas
Message 9 of 10
gilsdorf_e
Oh, that's funny. I did the same with Inventor API recently. After keyusers tests we will roll that out to the complete company.
protected override void ButtonDefinition_OnExecute(NameValueMap context)
            Document doc = InventorApplication.ActiveDocument;
            if (doc.DocumentType.Equals(DocumentTypeEnum.kAssemblyDocumentObject))
                //für Baugruppen
                AssemblyDocument thisAssembly = doc as AssemblyDocument;
                if (thisAssembly.ComponentDefinition.IsiAssemblyFactory)
                    iAssemblyFactory factory = thisAssembly.ComponentDefinition.iAssemblyFactory;
                    iAssemblyTableRows rows = factory.TableRows;
                    foreach (iAssemblyTableRow row in rows)
                        factory.CreateMember(row);
                else
                    MessageBox.Show("Das ist kein iPart und keine iAssembly!");
            if (doc.DocumentType.Equals(DocumentTypeEnum.kPartDocumentObject))
                //für Bauteile
               PartDocument thisPart = doc as PartDocument;
                if (thisPart.ComponentDefinition.IsiPartFactory)
                    iPartFactory factory = thisPart.ComponentDefinition.iPartFactory;
                    iPartTableRows rows = factory.TableRows;
                    foreach (iPartTableRow row in rows)
                else
Additionally keyusers tell me that the generation seems a lot faster in Inventor 2018, without inital lag like with right-click "Generate members".
Message 10 of 10
gilsdorf_e
in reply to: gilsdorf_e
Be aware that if you are connected to Vault, in case of iAssemblies with subassemblies all components must be already on local disk, otherwise you will have unresolved references.
