see the thread in R6 posted by John Elliot of Autodesk
reposted here..(Don't know why it didn't get posted here too?)
_________________________________________________
"Are you seeing this problem in R6 or R7?
text garbled (some characters black boxes) after save of drawing
Here's a quick workaround that should help users suffering from this
problem --
Find or create the following registry entry:
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion7.0\System\Prefe
rences\Driver
REG_DWORD "Text Options" = 0x00000000
Run Inventor and see if the problem no longer happens.
We need to know if this does not fix this problem.
John Elliott, Autodesk Inventor QA
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
