Additional information: If I move the cylinder to the point where the lining
hole is no where near the cylinder hole, I can no longer add a second
insertion constraint between the cylinder and the rest of the assembly. If I
move the lining so that the hole is closer to the cylinder hole, I can then
add the constriaint! The only constraint on the lining is an insertion
constraint with the cylinder, it has no "official" connection to the rest of
the assembly.
Tony
"A Vienneau"
wrote in message
news:3ffc6795$1_1@statler...
> I just came across an interesting situation. I think that it may be a
> nuisance bug, but it could also be me not understanding the subtleties of
> constraints.
> I have a lining in a cylinder and a hole passing through both. The hole in
> the lining is derived from the hole in the cylinder. These are part of a
> larger assembly. When I have the cylinder only partly constrained to the
> rest of the assembly I can move it independently of the lining AND the
hole
> in the lining without IV requesting an update.
> If I constrain the cylinder fully, the hole in the lining immediately
> updates and will no longer move.
> Important? note: When the hole in the lining was created the cylinder was
> fully constrained. Some changes to the flange meant that the constraints
> needed to be recreated. That's when I noticed the behavior.
> Tony
> IV8
> Assus P4S533 mother w PIV 2.4G
> Win2000 Sp4
> 512Mb
> 3G Page
> Quadro4 750 XGL 128Mb driver 6.14.10.4472
> IE 6 Sp1
