I tried to match the dimensions of the already existing product with new dimension through fx parameters(using link excel sheet), while conversion all the dimensions are changed except taper value (By default it comes with inch instead of degrees)
It can be changed by adding user parameter but i want it to consider from excel sheet data itself.
Is it possible?
For reference i have attached the snap shots
Solved by SBix26. Go to Solution.
Add a third column to your spreadsheet to specify the units: | Tap2 | 10 deg | deg |
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 2
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
SpaceExplorer/SpaceNavigator NB, driver 3.16.2
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
