I made this part:
And I noticed this artifact:
This is how I made it:
Thoughts?
It's not there in the flat, nor is it visible in the drawing. It's not affecting my work at all, but I thought it was worth asking about.
I think it comes from the radius you did before you refolded the part. try to do it after you refolded the part..
@mrattray wrote:
Thoughts?
The part could be made with two features.
Contoured Flange
Cut (Across Bend) - with a trick.
I tried using cut across bend. I got an error message that I can't use it on a sketch that lives on a workplane. What's the trick?
I am really interested in the result you showed in the image. Could you attach the dataset for more investigation?
That planar face is needed for Cut Across Bend as it cannot be done from a workplane. (sketch must be on a part face)
It could have been removed as part of the Cut Across Bend. (cut it (with a rectangle) and your rectangular hole at the same time)
I normally make it a little larger (so easy to see) and then make the dimension really small after part created.
(attached saved in student version - delete after examination and re-create)
I figured as much, but that doesn't seem like a good technique to me. I assume this is the trick you mentioned earlier. How is this a better technique then the one I used?
This is the way we did it before UnFold/Refold existed.
Check the file size using both techniques (and the fillets could be added in the Cut sketch).
The difference in file size is 80kb, or 21%. I think in terms of modern storage mediums, 80kb is pretty much neglegible. However, I can see how it could be a much bigger difference on a large complex part. I think I would consider it a better technique if it didn't require the tittie at the end of the roll.
I know the rounds could be in the sketch, but I feel that having them as a seperate feature makes them easier to edit, especially if I ever needed to remove them. Do you have a good reason for them to be in the sketch, and a trick to deleting them without having to deal with disconnected lines?
I agree with you I never use sketch radius for the reason you mention. The only time I do is for sweeps or lofts..
