Inventor Forum
Fundamental change of geometry near the end of a project
2 REPLIES 2
384 Views, 2 Replies
I am designing a vacuum part in Autodesk Inventor, which is essentially a long cuboid shape with various valves and spaces for windows along it's length (see attached pic). Upon finishing the design of this part, a few details need to be changed - one being the fundamental shape of the object. It now needs to be a larger square section attached to a long cuboid section (as I found out the valves on the right hand side of the drawing are around double the size they are in this drawing). Rather than restart the project from scratch, I would like to only modify one of the ends to be extruded out into a square shape, or something like that. My first idea was to use the split command in order to split the faces into what I did and didn't want to change, but upon starting this, I don't think this is the best way. Does anyone have any ideas on how I could do this? Thanks.
2 REPLIES 2
In the end I chose to split the model and begin some new sketches and extrusions on this part, which worked fine after some initial material hurdles.
SBix26
Tip for posting images in the forum-- don't use bit maps, they're enormous.  Use .jpg or .png formats instead (Windows Paint can make the conversion, as well as most other image processing apps).
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
