I have a big assembly consisting of a large number of sub assemblies and parts.
I would like to be able to quickly show color alternatives. All painted parts will be painted in one of two colors.
I would like to have a function that takes two color arguments that will set the color of a number of parts
to the first color and some other parts to the second color. Not all parts need to be painted.
I have seen solution on this forum to set the color of all parts in a assembly to one color.
But I have two sets of parts for different colors and not all parts need to be colored.
How can I do this best? iLogic? How do I have to input the colors?
How to deal with repeating patterns (should still work when changing the repeat count)?
Also, there should be some text on some parts. Can I also change this text color automatically?
I still have to change all part colors manually when using view representations. Do I?
View reps store appearance overrides. So you model everything using the appropriate colour, then in the assembly, set the override colour whilst you have one of the view reps active.
With two view reps (and the "Master"), it's no more than a double-click to switch from one representation to another. You can also right-click a view-rep to strip all colour overrides if something goes wrong.
But yes, the initial colouring of each component (part or sub assy) is done once manually. Don't forget you have some great selection tools like constrained-to, sphere offset, window select etc. These will help you quickly the apply initial colour overrides.
