Anyone know if FRP is available in Autodesk Inventor's material library? I don't see it there but maybe it falls under a different name. If it's not in the library is there any way to add new material?
Jordan
Solved by JDMather. Go to Solution.
Go to the Material Browser to add a New Material.
Thanks JD. This is good to know for future reference but I actually found the material in the library after all.
Would you be able to share where you found the FRP materials in Inventor? Is this just the material or also the shapes in Content Center?
