Will somebody please have a look to my part? I'm trying to learn to draw contour lines inside empty places of parts, connect those lines and end to a solid.
I tried various ways I know theoretically, but still fail to realize this practically.
For instance, after drawing lines (as you can see on the part) I made surfaces, then stich and skulp, but it says "not smooth lines" and same times smooth-constaint won't work on my lines. Can't understand why.
I also tried "loft" but no success too: when I make a surface and use guide lines, it gives error too.
I think there is a small mistake, please point me out of the problem.
Hi, (for France)
You can made surfaces, then skulp..create a new solid.
You can see on this jpg file attached.
Camel.
