The very annoying thing is that you can change the page size to A4, but the title black and the drawing remain at A3, so EVERYTHING needs to be rescaled and adjusted.
Did you click on BETS FIT and also check your printer setings, as that sound like the printer was also set for A3
The IDW that you see in the background of the following screen shot is on AO it DOSE print to A4 with out any problems
However, the scale on the drawing is now wrong, and the size still reads A0.
Can the size of the whole drawing be changed with a single click (or three)?
Other option
1) Create a set of title blocks 1 for each size of paper, save as a template & use that as your default IDW template
2) Ste the sheet to A4
3) Use the scales in the Edit View
4) |Print it out
Hi Paul,
Thank's - I had thought of that. However, the frustrating this is that it should be doable with a single click. We shouldn't have to produce such a work around as you describe for a siftware package like this.
