Inventor Forum
Friday Pictures?
74 REPLIES 74
Message 1 of 75
3813 Views, 74 Replies
Friday Pictures?
Haven't seen any in a while though I haven't been on here as much lately either.
Here's a couple FIAT parts we're getting ready to release.  First is a Torque Strut (rendered in Showcase) and the 2nd is a WIP Upper Front Strut Mount replacement.
What are you guys/gals working on today?
74 REPLIES 74
Message 41 of 75
jeanchile
in reply to: cwhetten
@cwhetten wrote:
Something like this?
HAAA!!
Yes... exactly like that.
Inventor Professional
Message 42 of 75
karthur1
Been working on this on/off for a while now.  This is a tool to weld automotive lens together.
Kirk
Message 43 of 75
graemev
in reply to: jeanchile
@jeanchile wrote:
... a pig launcher...
Does working on a modern trebuchet count?
Message 44 of 75
mrattray
in reply to: graemev
Post it!
Mike (not Matt) Rattray
Message 45 of 75
graemev
in reply to: mrattray
It's a LONG way from complete, but here's the arm assembly so far.
Specs:
   - 75" axle to hook tip
   - rope-over-cam counterweight attachment
   - 18" radius cam
   - 1000lb counterweight (24" x 24" x 1/4" steel plates in carrier rack)
A comparably sized trebuchet with the usual free-hanging counterweight should launch a 10lb... pumpkin... about 600ft downrange.  I'm hoping this new design can up that to about 750ft.  (900ft would be the theoretical range if 100% efficient.)
(What does one have to do to be able to post something larger than 5kb?!?)
Message 46 of 75
mrattray
Sounds sweet!
The site is messing up today. If you post it as an attachment instead of as an inline image it should work.
Message 47 of 75
graemev
@mrattray wrote:
Sounds sweet!
No.  No it doesn't.  Maybe I'll try again later.  {sigh}
Message 48 of 75
mrattray
Try it again, I think it's just been fixed.
Message 49 of 75
graemev
Aye, Captain.
Message 50 of 75
Fire Rated Curtainwall and Door
Message 51 of 75
Hey - I've done some stuff that looks like that too!
I have a buddy who owns a retail GC company and occasionally I help him "visualize" suggestions to clients.  Kind of fun and always makes the clients happy.
First pic is one of many options evaluated for tile layout in an entryway, second pic is a recommended change to the architects misunderstood vision of how to incorporate a linear diffuser into a complex ceiling construction.
Message 52 of 75
Had to accept the "clarified" pig launcher graphic as the solution for this topic.  Well played, sir.
Message 53 of 75
mpatchus
Sorry, but I just had to model a flying pig...
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 54 of 75
in reply to: mpatchus
Hi all,
Just thought I would add a pic of a job I did a few years ago.
It's an pnumatic actuator for cooling the turbine case for a Areo engine.
Message 55 of 75
stephengibson76
what depth can you launch your pig at?
Stephen Gibson
View stephen gibson's profile on LinkedIn
Message 56 of 75
-niels-
Had to do a render for some internal document, so got to play with showcase a bit.
Decided to make a few images for this thread as well.
It's one of our small carried sprayers, kind of a shame i didn't have a version with proper hoses modelled in...
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 57 of 75
Mark - what did you use for the rendered top image?
Message 58 of 75
Hi Gsmith9810,
It’s rendered with Max, plus lots (& lots) of post tweaking with photo editing.
Many thanks and kudos should go to the photoshop expert guru’s I used to work with.
The main tip I picked up from them is render oversized, post edit (insert black magic here Smiley Wink)
shrink/ downsize image.
Mark
Message 59 of 75
Thanks Mark! Your render looks great. I'm basically lazy when it comes to renders. If I can get useful out of the default, I will. I've been having trouble importing into Showcase but so far I have ALWAYS been able to get assemblies into Showcase by taking them through Navisworks first. One of the tasks that I perform here is taking the "beauty shots" of finished tools prior to shipping. As you note, the larger the initial image, the better and layers and layers of post-production. Over the years I have encountered my share of designers who use "clown colors" while modeling. I generally try to take a model back to what it will look like in "real life" for illustrations in the books I produce. They generally aren't photo-realistic, but cranking out a 9000 x 9000 render at 300dpi is usually going to work for publication.
Message 60 of 75
LFMarshall
Here are a few things I've worked on over the past few months.
Larry Marshall
Inventor 2021.2 , AutoCAD 2021, 3DS Max 2021
