Haven't seen any in a while though I haven't been on here as much lately either.
Here's a couple FIAT parts we're getting ready to release. First is a Torque Strut (rendered in Showcase) and the 2nd is a WIP Upper Front Strut Mount replacement.
What are you guys/gals working on today?
Solved by cwhetten. Go to Solution.
@jeanchile wrote:... a pig launcher...
Does working on a modern trebuchet count?
It's a LONG way from complete, but here's the arm assembly so far.
Specs:
- 75" axle to hook tip
- rope-over-cam counterweight attachment
- 18" radius cam
- 1000lb counterweight (24" x 24" x 1/4" steel plates in carrier rack)
A comparably sized trebuchet with the usual free-hanging counterweight should launch a 10lb... pumpkin... about 600ft downrange. I'm hoping this new design can up that to about 750ft. (900ft would be the theoretical range if 100% efficient.)
(What does one have to do to be able to post something larger than 5kb?!?)
Fire Rated Curtainwall and Door
Hey - I've done some stuff that looks like that too!
I have a buddy who owns a retail GC company and occasionally I help him "visualize" suggestions to clients. Kind of fun and always makes the clients happy.
First pic is one of many options evaluated for tile layout in an entryway, second pic is a recommended change to the architects misunderstood vision of how to incorporate a linear diffuser into a complex ceiling construction.
Had to accept the "clarified" pig launcher graphic as the solution for this topic. Well played, sir.
Sorry, but I just had to model a flying pig...
Hi all,
Just thought I would add a pic of a job I did a few years ago.
It's an pnumatic actuator for cooling the turbine case for a Areo engine.
Had to do a render for some internal document, so got to play with showcase a bit.
Decided to make a few images for this thread as well.
It's one of our small carried sprayers, kind of a shame i didn't have a version with proper hoses modelled in...
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Hi Gsmith9810,
It’s rendered with Max, plus lots (& lots) of post tweaking with photo editing.
Many thanks and kudos should go to the photoshop expert guru’s I used to work with.
The main tip I picked up from them is render oversized, post edit (insert black magic here )
shrink/ downsize image.
Mark
Here are a few things I've worked on over the past few months.
