Show only
Search instead for
A suggestion: you might try perspective view and a background image to increase the realism.
You could also save the lap shingle siding texture as a black and white image and assign this image as a bumpmap for the color, this would give a more 3D look.
----------------------------------------------------------------------------------------- Autodesk Inventor 2019 Certified Professional Autodesk AutoCAD 2013 Certified Professional Certified SolidWorks Professional
So, is this one of the assemblies in which DA was deleting files? If so, can
you send us the models now? If you can, I'll add your models to the issue in
the data base as one more point of reference.
This stuff is going to be used a lot!!
no more corny wire frames for technical illustrations!!
Thanks Autodesk, an actual improvement!! hahahahahaha
only kidding, sorta
