Solved by johnsonshiue. Go to Solution.
Sorry, its been a while.
It works without Compatibilty, and it worked with Performance and software graphics.
Hi! Based on your reply, it does seem like the graphics driver on your machine is not working well with Inventor. It is hard to tell where the exact problem is without seeing a reproducible case. Have you updated the graphics driver?Regardless, at least Permance + Software graphics works for you.
Thanks!
I haven't tried it without the graphics box checked, but I will. I'll look into updating my driver. I'm going to the FRC championships in St. Louis, so I'll show it to the people at the Autodesk booth there, so you guys can have some direct data, and can use it to make Inventor even better.
Soory to but in yourblog but you gys seem to know your stuff. I am running autucad 2015 and it keeps freezing after modify commands. this is happening both on my personal brand new PC and the network computer at the college I teach...any ideas on a fixit!!
@Anonymous wrote:
.... I am running autucad 2015....!!
This is the Inventor forum - not AutoCAD.
Hi! Go to Tools -> App Options -> Hardware -> Conservative mode.
Many thanks!
