Gang...I noticed on another users workstation that when the do a free move / rotate, they get a rubber banding effect. I don't see this. Is there a Application option which affects this?
Thanks in advance,
Steve H.
Solved by -niels-. Go to Solution.
Not that I've seen.. But they like to "hide" settings sometimes..
Have you tried updating your graphics card driver?
Do you have the same settings as the other user for tools..application options..hardware tab?
If you right-click with the "free move" command active, there should be a "diagnostic" option in the top of the radial menu.
Is that checked?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
