I am using Frame Generator to make the frame for a trailer. After numerous edits and stress analysis, I am unable to see the frame/ skeleton part in the view window. It is still in the browser however, and the visibility is on. I've attached a picture. Essentially, I have edited the base part file for the frame and need to add members based on that edit. When I open "Insert Frame," I cannot see the frame lines to add a member. Is there a fix for this?
Is this happen even closing and open it again?
Admaiora
Yes, the problem persists even upon closing and re-opening the assembly.
If it is not to big you can do a pack and go and post it for a quick solution
Admaiora
Hi Spreston91294,
Have you tried Isolating the Skeleton Part?
There are 2 ways i can think of off the top of my head.
1. Right click on the part in the broswer and select "isolate" ( Just make sure you "Undo Isolate" once your done)
2. Turn the Visability of the frame off.
I hope this helps,
James
