Hey again guys,
Another question using IV 2013 and Frames.
When i get some frames and need to use the feature NOTCH, is there a way to put one offset on it ? like we can do using MITER ?
The solution we've found here is in every member that we use NOTCH, we enter in the frame part and then use the feature THICKEN/OFFSET, this wey i can get the standard offset of 3mm that we use here for welding.
Or, if there is other easy way instead of NOTCH, to make one frame get to other with offset.
The image below shows what i mean, i need to get this off set in the frames on Z AXIS.
Thanks very much!
Túlio Barata
Thanks man!
Well, a good way to solve it with that answer, better than mine when i get many and many frames...
Túlio Barata
