I am new to using Frame Generator....i attach picture of frame and welded joins.....I have also attached my attempt at a frame..
In the picture the frame is welded together......please how do i add the welds to my Frame so it looks identical to the picture
Thank you
Paul
INV2013
You could add a Groove Weld to fill the gap.
OK,,,thank you
Is it also possible to do the Weld like in the picture attached
Is the Weld feature easy to learn....never attempted before
Thank you
Paul
Most welds will show the welding beads, depending on the options selected, such as grind flush, etc. If it is ground flush it will then appear as flat metal. It's not that difficult to learn, just takes patience to first figure out all the settings. You can at the same time create your welding symbol for display on the drawing.
A quick one to show appearance:
Thank you
In my model will the weld fill the gap between the base frame and the legs....I am going to read up on how to perform the weld techniques
Paul
paul,
This is typically how I do HSS welds in Inventor. As JD mentioned, a Groove weld works the best.
To accomplish this select the end face of the one HSS tube. Then select the radius of the intersecting tube. Finally be sure to select Radial Fill.
Hope this helps.
