I am using IV 2010. I am creating an assembly using frame generator. I have finshed my first frame everything is good. I need to make another frame identical with exception to one part. How can I use the first frame to make the second? I have saved the skeleton as a new name and saved the assembly as a new name and did a replace with the skeleton then modified the skeleton to get the desired change. When I make the change the old assembly changes as well. I am trying to avoid making the assembly twice because of one part. thanks.
