I've just installed V2014.
Created a 2D sketch on an assembly then open the frame generator, i can select frame member, orientation, etc. but i can't apply because it won't let me select any of the lines I've sketched, this had never happened on V2011 I had before.
Please, help.
Solved by Curtis_Waguespack. Go to Solution.
Hi jorgea.riverav,
The frame skeleton sketch needs to be created in a part file, and the part file is then placed into the assembly and used to place frame members. You can not use a sketch placed at the assembly feature level for the Frame Generator.
I hope this helps.
Curtis
