I have recently build a frame structure using the frame generator. Now i wish to change some beams to other positions which is fairly easy. The only problem i have is when I click on the insert frame button the selection window does not appear. the function does work but it is like working in the dark 🙂
Does anyone know how to open the insert frame window manually?
kind regards,
Thomas Hjortnaes
False alarm 😛
The previous time i used inventor I had my laptop connected to a second screen. When the laptop then starts without that screen It forgets to reset all window positions to the first screen.
It was only a matter of reinserting the screen and the insert frame window reappeared.
If you were working on the problem, thanks for the time anyways
T.
