Hi Gary,
That is what I thought. I think framegenerator is a huge time saver but if
the partslist issue cannot be cleared up, that is going to be a huge
problem. The shop is not going to appreciate a partslist with the exact
same part appearing in multiple lines. Hopefully Autodesk has an answer for
this.
Rob
wrote in message news:5164940@discussion.autodesk.com...
Hi Rob
The Frame Generator is a good function, but Autodesk have not thought about
the process of part information when you use steel frame structures, ie
stock number, part number, description, material grade etc. This problem
relates back to the way the steel members are arranged within the data base.
What we need is a method to modify the data base in how the information can
be displayed.
