Inventor General Discussion
Valued Contributor
4 Kudos
Post 1 of 11
Frame Generator Trim/Extend
1158 Views, 10 Replies
03-05-2013 08:17 AM
Having issue with trimming a frame out in between two pieces. I am sure it has to do with the starting and ending planes but would like someone to look at this. I have a 1.5"x1.5" square tube I need to trim in between a space about 1.5". The sketch extends the two perpendicular pieces and just cannot trim one end. I seems to trim where I dont need to trim. See photos.
Chris Biggs
Engineer/CADD Services
New Horizons RV Corp.
2401 Lacey Drive
Junction City, KS 66441
Dell XPS 8300
Intel(R) Core(TM) i7-2600 CPU@3.40GHz
16GB RAM
Win 8.1 Pro
Autodesk Product Design Suite 2014
1,702 Kudos
Post 2 of 11
Re: Frame Generator Trim/Extend
03-05-2013 08:34 AM in reply to: Cool_Breeze_Jr
Hi Cool_Breeze_Jr,
Is it possible that you used Trim to Frame rather than Trim/Extend to Face. I don't see the issue when using Trim/Extend to Face, but can sort of replicate it depending upon selections when using Trim to Frame for the first end treatment.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Valued Contributor
4 Kudos
Post 3 of 11
03-05-2013 09:01 AM in reply to: Curtis_Waguespack
Hey Curtis, Thanks for replying lightning fast! And thanks for the quick pics as well. Being first year Inventor user I am still learning alot.
One piece of the puzzle I failed to mention is that the top long piece is at an angle something like 2 degrees.
I am going to lunch, will check back in about an hour.
Chris Biggs
2401 Lacey Drive
Dell XPS 8300
16GB RAM
Win 8.1 Pro
Distinguished Mentor
52 Kudos
Post 4 of 11
03-05-2013 09:58 AM in reply to: Cool_Breeze_Jr
Sometimes inventor will do this depending on the parts starting point. To fix lengthen the part you are trying to trim first in the direction of your trim so that the to be trimed side is longer than the side it is actually trimming. Then apply the trim and it should trim properly. Trim the one you did last first after you lengthen it. Your first trim needs to be last and that is the side you should lengthen about twice the distance so the part is longer on that side. Then inventor will know what is to be trimmed. The trim command not only uses base points, but also how much sticks out past the face you are trimming to. Your last trim happens to be at the parts base point so by default it tries to keep that side. After you lengthen the opposite end trim to that face first.
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
Intel Dual Xeon E31225 @ 3.1 GHz CPU
16 GB RAM
NVIDIA Quadro 600 GPU
Windows 7 - 64 Bit
Valued Contributor
4 Kudos
Post 5 of 11
03-05-2013 10:05 AM in reply to: swhite
SWhite, I tried this in  my situation, no luck. Sry...
Chris Biggs
2401 Lacey Drive
Dell XPS 8300
16GB RAM
Win 8.1 Pro
1,702 Kudos
Post 6 of 11
03-05-2013 10:09 AM in reply to: Cool_Breeze_Jr
Hi Cool_Breeze_Jr,
If you remove all of the end treatments from this member, and then use the Trim/Extend tool are you able to get more predictable results?
I hope this helps.
Curtis
52 Kudos
Post 7 of 11
03-05-2013 10:54 AM in reply to: Cool_Breeze_Jr
I'm sorry, in this example you will need to shorten the base side not lengthen the opposite end. It is usually one or the other for future reference.
What you get:
After first trim and shortening the base side:FG2.PNG
End result after final trim:
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
16 GB RAM
Windows 7 - 64 Bit
Valued Contributor
4 Kudos
Post 8 of 11
03-05-2013 11:33 AM in reply to: swhite
OK I got that, but I just cant understand why it just wont trim out like I want it to. I got aroun it by trimming the end that is slightly angled and shortened the flush end 1.5". It works but should be alot easeir though.
Chris Biggs
2401 Lacey Drive
Dell XPS 8300
16GB RAM
Win 8.1 Pro
52 Kudos
Post 9 of 11
03-05-2013 11:50 AM in reply to: Cool_Breeze_Jr
Make sure you shorten it more than needed and then trim it to the surface, othewise if you change spacing between tubes that one wont update.
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
16 GB RAM
Windows 7 - 64 Bit
Valued Contributor
4 Kudos
Post 10 of 11
03-05-2013 11:57 AM in reply to: swhite
Yeah I did, it will work but I cant bring myself to 'accept as solution'.
Chris Biggs
2401 Lacey Drive
Dell XPS 8300
16GB RAM
Win 8.1 Pro
