Inventor Forum
Frame Generator Problem April 22/2014
7 REPLIES 7
Message 1 of 8
RotorCAD
802 Views, 7 Replies
Hello everybody,
To start off I am using inventor Pro 2014.
I have used frame generator plenty of times with zero issues. It's a fundamental aid to our in house tooling design and is a great tool.
As of today I needed to create a small guesset, I snapped a couple lines in opend the frame generator dialog box, selected my lines and custom profile (extrusion) to be used they automatically update, visually I can see that it is what I want but when clicking "apply" or "ok" they just dissappear leaving me with a "+" under my mouse pointer.
I unselected the "Prompt for file name" check box in hopes that maby a second dialog box is off screen.
I have tried a seperate assembly, same problem. I have gone as far as restarting the CAD work station again to no avail.
Thanks in advance for any help that may come.
-Justin
7 REPLIES 7
Message 2 of 8
MariaManuela
in reply to: RotorCAD
Hi Justin.
Welcome to Autodesk Community.
Can put a picture of what happens?
Asidek Consultant Specialist
www.asidek.es
Message 3 of 8
RotorCAD
in reply to: MariaManuela
Above is after i selected the 2 random lines and clicked apply, you can see the buttons "apply" and "ok" have shadowed leading you to belive the operation is complete but the frame is not inserted and I am left with the skeletal model
-Justin
Message 4 of 8
MariaManuela
I see...
This also happens with profiles that come in Inventor? Or are you just happen with customized profiles?
Once happened to me a similar thing, but i had been working with 2 monitors, and then when I returned just 1 monitor some dialog boxes did not appear and I could not finish operations (happened in this function). You worked with expanded monitor recently?
Can also always install the latest Inventor 2014 updates
www.asidek.es
Message 5 of 8
RotorCAD
Yes I do work with dual monitors and this problem has just started today.
I have also tried some of the pre loaded profiles (ANSI Standard stuff) to no avail.
I will try to loading the new updates and report back
-Justin
Message 6 of 8
RotorCAD
I insallted the updates.
still not working.
-Justin
Message 7 of 8
RotorCAD
Ok, I made some progress..
It seems that if I place the skelal model as an IPT into my master assembly, (where other frame generated assemblys lay)
I then can use the frame genorator and select the lines and replace them with a frame profile of my choice.
However, if I create a new assembly it will not work. Would this have anything to do with a Project associativity?
-Justin
Message 8 of 8
RotorCAD
Must have fixed its self. seems to be all sorted out!
thanks
-Justin
