I commented on this elsewhere but it's probably more appropriate on its own.
I made a quick frame generated frame (I also randomly plunked a couple members in not associated with the frame) and for some reason the length in the description which is linked to the {B_L} expression shows up for 12" or 0.001" (depending on the image I treid two separate .IAM files) on everything???
If you look at the base qty value or even the part name length value it shows the correct lengths of the two different tubes, neither of which is actually 12". And yes the value in the part number expression is {B_L} also.
I just checked using the bolted connection generator....it shows correct lengths of bolts (which I also customized) in my custom BOM column. So it has to be something in Frame generator.
This is pretty cumbersome.
Solved by LT.Rusty. Go to Solution.
Oh! Oh oh oh oh! I just finally remembered what the issue is here.
Use G_L, not B_L.
B_L is base length, and it is inserted based on the B_L that is generated by the table. G_L is the length of the piece of steel after all modifications are done to it - miters, notches, etc. G_L will equal B_L to start off, and then modifications later will adjust it. So, B_L in the table is usually going to be .001. When you do PLACE FROM CONTENT CENTER you manually enter a value to replace B_L, so that's why your part numbers come out right. When you insert from Frame Generator, B_L is never looked at - only G_L.
Rusty
Little things like that get you all tied up....thanks!!
I'm going to the tavern now!
Hello All.
For me, it is not working.
I have tried both B_L and G_L. If added to Description column does not work.
Shows correct length in Part number column using the same parameter.
Please look at the link below
Regards
Parag
