I am trying to apply a miter to two frame generator members but there's a catch. I want one member to have a typical 45° miter and the other member to have a 45° miter through only part of the member. Is this possible? I've attached a detail of what I'm trying to accomplish.
As was simplified for me by another user, I don't want to include the top flange in the miter.
This post confuses me, it is dated June 13th, but showed up as new today, and there is no detail attached.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Sounds like you want to do a custom mitre. If that is the case what you get with the mitre tool in FG is what it is.
If you want something outside of that, you will have to create either a custom cut in the assembly ot modify the individual members to show th mitre cut you need.
Chris,
I am suspecting he changed the status of the post to "New" probably because he did not get any reponses the first time.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
