i have created a user parameter in a assembly, then creating a member with FG i use that parameter as memmber offset.
The same with other members.
Changing from Parameters that parameter no update happen,
I have tried rebuild all, refresh..no working.
The only thing that works, is to use the "change" command , select my member(s) , change nothing, than ok.
Then it update.
Is it a software limit? A bug? An error in the workflow? Thank you guys
When you say offset parameter, are you using this in the skeleton sketch? The sketch is what drives the FG assembly.
What does your parameter look like, code?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
No.
I mean a user parameter at level assembly, and inserted in the frame generator window setting as offset.
Very simple Offset1=30
I leave the skeleton sketch untouched.
It works only if i use change member command, select that member, than click ok. Then it finally update.
