Inventor Forum
Frame Generator / iPart sketch / visibility issue
5 REPLIES 5
608 Views, 5 Replies
so, I create a simple sketch. I have made a sketch in a new .ipt of a rectangle with two dimensions. I have made this .ipt an iPart with only four different sizes.
I open a new .iam assembly file. I use "place component" and place the iPart file that only contains a rectangular sketch. I select the size and place the component. The problem I have now is that I can not see the sketch.
What I was aiming for was to use this sketch to make a simple frame using the Frame Generator (then changing the .iam into an iAssembly). Since I can't see the sketch, I can't make the frame.
Does anyone know if this is possible?
IV2008 (SP2)
5 REPLIES 5
Is the visibility setting on the IPT's sketch enabled or check the
visibility settings under "View". This is standard "Skeletal" modeling
process, sketch is visible unless a setting has it turned off.
Dell 670 dual Xeon - 3.2
3gb memory, SCSI320-15k
XP-Pro, sp2
Quadro FX3400: Driver: 91.36 OpenGL
IV2008-pro sp2,
SpacePilot Rel V: 3.5.4 Dvr V: 6.4.4 Firmware 3.12
wrote in message news:5822975@discussion.autodesk.com...
sketch.
IV2008 (SP2)
I have all visibility on, in the .ipt file, in the parts tree, and in the View drop-down-menu.
Sketches are not available in an iPart member.
"I have made a sketch in a new .ipt of a rectangle with two dimensions. I
have made this .ipt an iPart with only four different sizes."
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP3, AIP 2008 SP2, PcCillin AV
HP zv5000 AMD64 ( modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows XP Silver Theme
http://teknigroup.com
Geoffrey.m.Reynolds
You can with Imates  this it will now allow it to be shown on a AssemblyUntitled.png
josalgper
Hi, I'm trying exactly the same as you.
Did you finally do dhat ?
Thank you
