I have a frame controled by my skeleton sketch. Two plates that are used to mount a machine are associated to the skeleton and iLogic is used to adjust the dims in skeleton based on the selected machine and dimensions retrieved from the machine.
Last week the system was working perfectly. I would select a machine and the plates updated accordingly. but this morning I opened it up and the frame parts are not following the sketch. I edited the frame part using frame generator and as soon as I did that the preview indicated that the part was associated properly and would move to the location that the skeleton had adjusted it's self too. But as soon as I clicked ok it the complete part snaped back to the position designated for the smallest machine size and it will not update. I don't understand how the system can be working fine on Saturday when I closed it and be messed up this morning when I have not done anything too it.
There is a work around by placing the parts without the frame generator being involved which I may do anyway but I should not be having this problem anyway!
Thanks for letting me vent!... If there is a fix to this that would let me keep the frame generator solution intact I'm all ears but I suspect I'm going to have to implement the work around.
Solved by cbenner. Go to Solution.
Have you tried "Rebuild All"? This is needed a lot when working with FG. Look on the Manage tab.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
You haven't posted your Inventor version, I would check to make sure you are current on all Service Pack's and Hot-Fixes for your version as well.
What role does the iLogic play in this? Is it possible that the rule has line items that are either messing with the FG structure to the point the left hand does not know what the right hand is doing? It is possible that while it worked when the session is opened for an error not to show up until the whole session is closed and reopened. I ahve experienced that before in other cases. Could someone else have been playing with other facits of this assembly unbeknownst to you?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Thanks for the input all, I had forgotten about the rebuild command and that did the trick.
As to the question of how i logic affects it. It's pretty straight foward the user selects the machine to be mounted in the frame, the code looks at that machine and gets info from reference dims I added to the files and inturn sends that to the skeleton that is controling the frame. The 2 plates are associated to that and adjust accordingly.
there are some if statements that move holes around but the position of the plates was the part that seemed to be broken.
Is there a command in iLogic that will trigger a rebuild all?
Check out this link for the rebuild command.
http://forums.autodesk.com/t5/Autodesk-Inventor/ILOGIC-REBUILD-ALL/td-p/2799332
