All of a sudden I can't get up my frame generator. I click into my frame > hit "insert frame", which is normally where the dialog box comes up, but I get nothing.
Anyone else come across this? Some urgent assistance would be great!
Regards.
First (obvious) question... you are in an assembly, right? Did you check to see that all of your Add Ins were loaded? Sometimes after a crash they can unload.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hi paulb108,
Could it be this?
http://inventortrenches.blogspot.com/2011/01/missing-dialog-box.html
I hope this helps.
Curtis
Good call Curtis.... having 2 monitors I've never had this problem,... so I always forget it can happen.
Chris Benner
Sorry for the dlay gents,
I am not at work now but can tell you that will be the issue. I changed my "primary" monitor and then all of a sudden could not use my bread and butter - the frame generator. Once I altered back to the original set up all was fine. I shall try that procedure when back in the office however.
Thank you.
Regards.
