I want to find a rectangular flat section of about 250x200cm and a 150x100cm.Is that possible?
I have the content library of ANSI,JIS,GB,ISO and DIN but i can't find anything in these libraries.
It would probably be easier to add to an existing library than to find exactly what you're looking for somewhere else. Do you have any custom libraries set up in your company, or do you just use the standard library out of the box?
Is this IV 2013? Do you use Vault?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Cbenner ,firstly, thank you for your answer.I'm a student and i have the student version of IV 2013.I downloaded this version from the site of autodesk and i don't know if there are other libraries,that i can download and install, except of these i have already installed at the same time i install the program.
The only difference between student version and retail version is the serial number and studen version will produce a baner "student version" on drawings with any part created with the student version.
You would need to "create" the desired shape and publish it to your own "My Library" or create a new library that is both "Read and Write".
The Autodesk Wiki-Help will be able to guide you through the process.
