All,
I have been working with some framing, generated via frame generator, and want to export this as a Revit family. However, I just don't seem to be able to get it to work. Doesn't seem to matter if I derive the assembly, create a simplified part or use a substitute LOD, I cannot get Inventor to successfully recognize Revit features. Does anyone have any experience with this and has found an effective workaround? Or is this just a current limitation of the tool? Any input would be greatly appreciated and please do not hesitate to contact me with any questions. Hope all is well and have a most blessed night!
Peace,
Pete
No problem here using the BIM Exchange within Inventor to create a Autodesk Exchange File for use in Revit.
Use the BIM Exchange Tab> Manage Tab>Export Building Components (looks like a house frame with floppy disc).
blair,
Just to make sure that I am following properly, these are the steps that I have taken
1. Create a skeletal frame sketch part
2. Place part in a new assembly
3. Apply a frame to the skeletal part
4. Apply corner treatments
5. Save the assembly
6. Open a new part file
7. Derive the assembly into the part file (I have also tried to save out a substitute part and simplified part from the assembly)
8. Navigate to the BIM tab >> Bim Ready Content >> Recognize Revit Features command.
9. Perform an autorecognize
10. Failure message
No matter what I try, I get an error message (which I am attaching), and the autorecognize does not successfully complete. Are these the same steps that you have followed? Also, are you performing this in Inventor 2015 or 2014? I find that if I just attempt to publish, the features not recognized simply do not come across into the Revit family model. Thanks for the feedback and hope this helps clarify what I am trying to accomplish. Hope all is well and have a most blessed day!
Peace,
Pete
blair,
Thanks for the update. I understand the rationale for the simplification tools, but we have found a limitation. The assemblies don't have to ability to be converted to Revit families, only parts have that ability. This is why we are trying to convert to a part first and then export to a Revit family. I am just trying to determine if the frame generator components won't work for this operation and then I will recommend trying to use the ADSK filetype.
