For years now my BOM's have had incomplete rollups due to formulas being missing - I just thought I forgot to copy them down. This time I was really carefull and there were still some missing. So I did some testing and found a bug.
Here's how it goes.
1. Create a frame assembly
2. assign a formula to the part number eg <stock number>-<G_L> (used for part number roll up)
3. Copy this formula to all frame members.
4. Edit frames by editing the sketch, or use design tab for mitering, extending etc.
5. save assembly.
6. Open BOM to find that formulas for all edited frame members are gone.
Problem is in 2011 & 2012 and I'll bet 2013 as well.
Can we have a hot fix please.
I've never run across this... odd.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
This has been the case for as long as I can remember. If you do anything to a FG model that would cause an update the formulas will be overwritten by FG.
Paul
@cbenner wrote:I've never run across this... odd.
Me neither - the only time I've ever noticed losing things like this are when I've changed the size of a member. Makes sense in that case, as it creates a new file.
If this is something you commonly do, could you get around the issue by having the custom formula in your Content Center family? If FG / CC was replacing your part with another one that has the same customization already in it, then your problem would disappear.
The last time I tested this any formula in a CC family was lost when the part is placed in a FG assembly. Your only option as far as I know is to paste the formulas in after the FG model is completed. I believe in Inventor 2011, maybe 2010 the behavor changed slightly in that the formula values did get passed through to FG but as static information, not the syntax of equals, less than, values, greater than sign, etc.
Paul
I never used FG or CC prior to version 2010, so I don't know how prior versions operated. However, I do have length updating properly on FG parts. It's been a little while since I set it up, so I may be missing some of the details, but this is my general setup.
First, I saved out a member from the family in my read/write library.
In the "Title" iProperty I added the formula:
= . . . . . <G_T>
Where the dots represent the rest of the component description.
This version of the part is then uploaded as the new Family Template. I then use substitution in my Parts List to use the Title in place of the Description where applicable. Everything updates properly.
I suspect the difference lies in the fact that I'm using a field that isn't actually written into by Content Center, so it never gets written over. I don't recall exactly why I used "Title" instead of "Description" when I set this up a year or so ago, but it may have been to avoid problems like the one that started this thread.
Thanks for sharing your method of using a custom CC family with FG.
= . . . . . <G_T>
This is the best practice if you want to eliminate the editing of the BOM data with Frame Generator. You can expand on this approach and create a complete set of custom iProperties to use with a custom Parts List so you don't have to use the 'Substitution' function in the Parts List if you desire.
Good Luck to all, Paul
@pauldoubet wrote:This is the best practice if you want to eliminate the editing of the BOM data with Frame Generator. You can expand on this approach and create a complete set of custom iProperties to use with a custom Parts List so you don't have to use the 'Substitution' function in the Parts List if you desire.
In my case, use of Substitution was intentional to solve another issue. My FG components are often shown mixed in assembly drawings with other components (various steel plates, sheete metal, purchased hardware, etc.) that use the normal Description field. The substitution prevents me from either having two columns to get all parts described in the list, or having to create and edit custom iProperties for every single model I make.
Also, the substitution itself is saved as part of the Parts List Style that I use for steel fabrication, so other than the original setup work in the Style Editor (done one time, over a year ago), it adds no additional work.
I need my BOM to show individual cut length quanties for each type of section and each length as shown below.
As far as I know the only way to do this is to have a formula in the part number field and use part number rollup. This way it groups all items of the same type and length. (I would think this should be much easier as just about every FG model would need a cutting list)
Check out this macro that was posted here a few years ago:
The formatting I explained earlier is what I use to generate my Descriptions. A slightly modified version of the macro is what I use to group the part numbers. It sets the Part Number field to "Stock Number x G_L", which is very close to what you were asking for in the original post.
In my case, since we use a different way of numbering the parts, I use it to group like parts together before I do my manual renumbering. It seems like it would be an even better fit for you. Any time something gets out of sync because of replacing members and such, you could just re-run the macro.
If you add your own part number column & custom iProperty for that part number to your custom CC you will be able to do what you need to with your parts list very easily. And you can totally eliminate editing your BOM data. The key is to have the information used in your parts list use custom columns from the CC family that are not overwritten by FG.
Paul
My iPart contained an expression for the part number, but I did not have it in my table. Publishing to the content center added a column which I was able to change using the editor.
